Broke ARP head bolt inside the block!!!!!
Old Feb 6, 2005 | 08:53 PM
MakoLS1's Avatar
it's on the bottom row, 2nd from the front. Its recessed about 3 in. in the block. Can't even see down in the hole to see if your going to drill centered and straight. I have a guy comming to look at it to bring an retracter rod and mabey weld inside the whole, like creating another hear bolt then mabey trist it back out.
I know the bolt pattern and torque specs were done right. DO u think ARP wil do anything about this??? They are arp bolts...
Old Feb 6, 2005 | 08:57 PM
shouldaboughtthez's Avatar
Re: Broke ARP head bolt inside the block!!!!!
I would save the pieces and contact ARP. Don't try to bullcrap them. They will probably take care of you.
Old Feb 6, 2005 | 08:58 PM
EddieP's Avatar
I didn't think they even threaded in that far (3")? In any case, I can't see how you'd be able to weld to it if it's that far in the block - it's hard enough welding to them when the break flush to the surface.
Old Feb 6, 2005 | 09:01 PM
jonaddis84's Avatar
Longshot, but if it threaded in easy try a magnet, again, longshot, but...
Old Feb 6, 2005 | 09:10 PM
MakoLS1's Avatar
does anyone know what ARP stands for to help me look the me look up their site to get a number?
Old Feb 6, 2005 | 09:16 PM
jonaddis84's Avatar
automotive racing products
Old Feb 6, 2005 | 09:26 PM
Kryckter's Avatar
No offense, But 3" sounds way too deep, Did you use the right bolt in the right hole, For instance, not using the longer bolts on the bottom holes, since it was the bottom row?
Just a thought, but ARP should take care of you if that was not the problem.....
Joseph
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
