Big inch, high horsepower LT1 4th gens, what are you using for headers?
I need a set of 1 7/8 headers that will clear the a/c box. Hedman has a set, but will not clear the a/c box. If you have a set on your car, where did they come from and can I get a set?
David
David
Might want to contact Dynatech about their 1-7/8" set. They should be able to tell you if they'll clear.
My route was "custom" but I do see more and more good header builders putting stuff together for 4th gens..... too bad all of it is for the LS crowd.
Good luck.
-Mindgame
Good luck.
-Mindgame
FWIW, I have a friend who has had the last few headers in his projects custom made.
It's much more expensive, in the $600 - $1,500 range, depending on complexity and coatings, but the fit is amazing, since it's a one off custom piece.
IF you are planning to make these pretty much the last set of headers you will buy for this car, then it may be worth it to spend the extra money and get a custom set made, complete with coating inside and out.
You can always get a kit from this place and build your own. Any large tube header will be expensive.
www.headersbyed.com
www.headersbyed.com
I found em here, http://www.lgmotorsports.com/OCLT1_Fbody_Exhaust.htm
But they are "off road use only" so you probably shouldn't use them.
Good luck.
-Mindgame
Good luck.
-Mindgame
Good luck.
-Mindgame
Good luck.
-Mindgame
David
I have the Hedman's on my motor. Pulling the heaterbox is something I decided to do....due to the nature of what the car is, but you can run them with the heaterbox if you notch a little part of it out. The other thing you need to do with the hedman's is to modify the #1 primary for clearing the steering nuckle (only required for power steering setups).
Its not that much work in all honesty.
Jason
Jason
I called Dynatech, they no longer make that header, Jason...Do you have to pull the a/c box off to modify it? DO you just cut a recess for the header to lay in? Have you ever done it or seen it done? how much room is there between the box and the evaporator? Anyone know or done this?
David
David
David, yeah you can just notch out the corner of the bow real easily. The actual heat exchanger is deeper in the box and will not get in the way. However, if you are retaining AC you will need to seal up the box good (either way).
Jason
Jason
