Best cam bearings?
Old Nov 21, 2004 | 05:14 AM
oil pan 4's Avatar
Best cam bearings?
Who do you think makes the best cam bearings for SBC?
This is not an extream engine but it will make some power.
I want them for my 3.4L, they will fit. It is commen for people to use them like that. I have more options this way and there cheaper than V6 cam bearings.
Old Nov 22, 2004 | 02:44 AM
amean94ta's Avatar
Re: Best cam bearings?
as far as i know the 4.3 shares cam bearing size with the sbc not the 3.4
the best cam bearing for a sbc that we use in all our race motors is durabond teflon coated i belive chp8t is the number
Old Nov 22, 2004 | 03:51 AM
oil pan 4's Avatar
I got it straight form the Chevolet Power manual.
It says:
"If new cam bearing are being installed, bearings from a small-block V8 may be substituted. These bearings are wider than production V6/60 cam bearings, so make sure that the lonitudinal position is correct."
So, I have durabond teflon coated so far.
Do I have any others?
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
