Bench Flow
Old Oct 14, 2003 | 03:54 PM
BUBBA's Avatar
Bench Flow
Probably in the wrong pew again, but curious as to how heads are flowed. Is the figure given at 28" for one cyl or all eight? If for one cyl then how could you possibly clainm that all 8 are the same, even with CNC?
If for all 8, do you assume that all intakes and exhausts flow the same?
Are they flowed with valves installed (i.e. is that how they can tell what the flow is at .200 or .600 lift)?
Mine flow 261/186 @.500. That's with 2"/1.56" Manley Race Flows. Would the larger undercut valves provide more CFM?
Can't recall seeing much on Flowing process. Sure find lots of bragging on numbers though.
Move it if you believe this can be answered factually in the Lt1 tech.
Thanks.
Old Oct 14, 2003 | 04:42 PM
OldSStroker's Avatar
Re: Bench Flow
28 in of water is the depression or amount of vacuum sucking air thru the intakes or blowing it thru the exhaust. That's just about 1.0 psi or approximately the vacuum in an unrestricted intake near torque and power peak. Each port is checked individually.
Never assume. Flow all of them.
Exactly right. A weak valve spring and a fixture with a screw pushing on top of the valve sets the lift.
Maybe, maybe not. Try them on the flowbench to see.
Thanks.
Yeah, guys like to brag about big numbers (except ETs and golf scores). Like a lot of things, it isn't always the size but what you do with it that matters...you know, cam timing, intake manifold, etc.
Old Oct 14, 2003 | 05:03 PM
BUBBA's Avatar
Thank you.
Formula Steve
Sep 19, 2023 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
canuck94z28
Aug 19, 2015 05:50 PM
Slayer
Aug 17, 2015 03:55 PM
camaro02DK
Jul 5, 2015 09:24 AM
