Battery Drain...
From: from the land of Justin Wilson and Huey Long!
Battery Drain...
What I want to know is...is it "urban legend" that if you put a battery on concrete, that it will discharge faster than if you place it on a piece of wood or some other insulator. May not sound too tech, but just wait. I truly don't know the answer. I'm interested in the theory either way. Thanks....
Personally I prefer cherry or some oiled teak, but if they aren't readily available at Home Depot, I just put the battery on the concrete floor.
Seriously, the only reason I see for using a wood underlay is to keep any acid which leaks or drips (from the old style batteries) off the concrete.
Battery trays in cars are usually steel, which is a fair conductor of electricity.
Battery case design about 30-40 years ago may let the battery drain when sitting on the concrete. With the battery construction now that has become an urban myth. I have a bunch of batteries sitting on the floor in my garage. None of them drain down.
Originally posted by OldSStroker
...Battery trays in cars are usually steel, which is a fair conductor of electricity.
My assumptions are probably correct...
Thanks....(although I did think it would get a bit more "technical")
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
