Backcutting a Performance Valve = Worth It?
Old Jun 9, 2007 | 06:09 PM
  #16
automotivebreath's Avatar
Originally Posted by thesoundandthefury
...You wouldn't happen to know if there's a specific term used to describe
that kind've back cut would you?
It's a patented idea called ST valves (surface turbulence). For information
look up the metric mechanic.
Old Jun 9, 2007 | 06:40 PM
  #17
thesoundandthefury's Avatar
Interesting stuff. I noticed in the little excerpt, it mentions that it benefits both carb and injected motors. I wonder if by injected, they're referring to the older Hillborn style injection, or if they actually mean EFI applications? I was always under the impression that sufficient fuel atomization wasn't a problem with electronic injectors.
Old Jun 9, 2007 | 07:12 PM
  #18
This one has it done to the face:
http://www.mpgresearch.com/garage.ph...d&image_id=118
Says it's from an '88 Dodge Daytona.
http://www.mpgresearch.com/garage.ph...c737fe1930be05
Old Jun 9, 2007 | 07:22 PM
  #19
Yes, Scott purchased those from the metric mechanic, I can't remember
if he claimed improvements from the valves. If I remember correctly he
did several modifications at once.
ssheen's Daytona
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
carl.froehlich
Mar 13, 2015 12:38 AM
