Backcut exhaust valves for more port velocity on exhaust
Old Aug 31, 2004 | 10:36 PM
TransAmTONY's Avatar
Can anyone explain to me what it means to backcut valves? I heard of someone doing this to exhaust valves to increase exhaust velocity flow on a turbocharged motor to help spool reponse. Has anyone seen this done before or understand how this process works?
-Tony
Old Aug 31, 2004 | 11:26 PM
MaxRaceSoftware's Avatar
Re: Backcut exhaust valves for more port velocity on exhaust
usually a 30 degree backcut valve angle after the 45 degree seat angle will increase Low Lift Flow on a FlowBench Test
when the Exhaust valve 1st opens while Cylinder Pressure Psi is still very high,
there is better Low-Lift Flow...higher Exhaust port velocity sooner
if the Exhaust Port flows more , yet its the same size, theres more Port velocity sooner in the Lift Curve / Engine Cycle
Old Sep 1, 2004 | 12:03 AM
interesting... thank you for your response.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
