Any advanced way of telling if valve springs are too small?
I used a LT4 Valve sping on my head and a 304 camshaft with 533/544 lift with a 1.6 rocker..
Looking back i think i was pretty stuiped for not changing them while i had the motor apart. But with a extra .20 lift will that really cause me problems? The camshaft shouldn't spin but to MAYBE 5900 or 6000.
I'm looking for a way to tell if they are not right for my application. I heard one guy say use a 1/16th feeler guage between the coils with the valve all the way open.. Any ideas on this?
Re: Any advanced way of telling if valve springs are too small?
But in general, the LT4 springs are good to 0.525" and no more, depending on the installed height. And given their relatively low rate, I would not install them higher to get the necessary clearance.
Rich Krause
one more thing, How do you check bind hieght? just by compressing the spring all the way to the head?
Valve lift+0.060" should be greater than or equal to installed height-coil bind height.
Rich Krause
My LT4 springs float at 5300 rpm with the lil' hotcam. As far as I'm concerned, they aren't any better than stockers. Since they cam with the car and I don't feel like yankin' them I just keep the revs down but thats the last spring I'd put in anything but a stock cam'd car.
