An advanced look at why Mustangs sound like they do
Re: An advanced look at why Mustangs sound like they do
Originally Posted by SSCamaro99_3
The heads are mentioned in that quote.
In my experience, the exhaust configuration is the determining factor of the sound characteristics.
Have you guys heard the Corsa on a vette??!!
http://www.corsaperf.com/flashc5.htm
It's the firing order. I have 4/7 swap cams in my stuff and they don't sound like anything chevy used to make. My 355 doesn't have the lumpity lump idle either with this type camshaft. you can also tell when a chevy does this with open headers as you can hear a steady exhaust pulse...you know like a mustang
Originally Posted by boosted-lt1
That's one of the reasons I'm a fan of the exhaust system being the driving force for exhaust note.
nateh makes good points in his posts early on in this most interesting thread.
Originally Posted by OldSStroker
Yeah, for about 80,000 miles on my '97 with CORSA Touring exhaust.
For you young people...a parity of a circa '70s brain tease:
If a Ford revs its engine in the forest and there is no one around to hear it, does it still sound like a Ford?
Originally Posted by marshall93z
i think you need your ears checked out!
a vette sounds like nothing else....and a 4.6 and 5.0 are totally different sounding!
I have heard SOME vettes that do, and some that don't , I can't explain why some do and some don't seem to, but i did not say all. And as I said some other things probably play a role also (exhaust type,etc) becasue i saw an ls1 corvette driving by, but before I heard it I thought it was a mustang. Who's to say if it's your ears or mine.
Originally Posted by DarthIROC
Lol
Potato Potato thats hilarious. Tell a 350 lbs Harley owner his bike makes a potato potato sound.
Potato Potato thats hilarious. Tell a 350 lbs Harley owner his bike makes a potato potato sound.I think you guys are confusing several seperate things as one.
First issue- There are inherent differences to engine designs. I can usually tell a ford from a chevy from a dodge, but it's gotten harder in the last 10 years. The people talking about how different make dragsters sound different with zoomies (same exhaust) are totally right. It's the acoustics. Ever seen the same band play at a football stadium, and at a proper concert amphitheater? (sp?). Huge difference. Thus, the BANG! of combustion will sound different in a dodge wedge chamber or hemi or chevy or ford. Not to mention the exhaust port & head acoustics. So does ignition timing. Want to deepen the tone at idle? Retard the timing 10 degrees. Different makes want different ignition curves, adding to different sounds.
Second issue, you can then tune the engine's inherent sound. And if you tune each make differently, you can move toward a common sound. I think merging into a single pipe makes them more alike. To some, single exhaust with a flowmaster sounds like a 5.0 stang, regardless of the car it's on. Others think they hear an IROC when my single & flowmaster elcamino is coming, so the chevy sound be recognizable somehow.
I'm a foundry engineer, whoever is talking about metals reflecting sound different is right on the money. Even small changes in the alloy compostion can change it. (like nodular iron) Heat treat also has a huge impact. Everything from the piston, head, block, valve, and exhaust tubing play a role in what's coming out the tip.
Great thread! Later
Originally Posted by mastrdrver
I always thought that the 5.0 sounded like it did bcuz of the design of the combustion chanber, atleast that was what someone told me.
The whole exhaust doesnt sound right. Have you ever heard a 302 vs a 351W? The 351W has a much higher pitch and doesnt sound anything like the 302, or am I wrong on this?
I have always thought that a small block ford has a much nicer tone than the SBC, the chevy's are too metallic sounding, the fords always have a nice deep rumble.
Originally Posted by PGR
Harleys sound unique because they are a 45 degree V-twin that fires every 405-315 degrees. "Potato-Potato" sound.
390 FE ford - two tacos - two tacos - two tacos
Originally Posted by GrayStangGTvert
I always thought the 351W's sounded more like a boat motor than the 302.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Apr 8, 2015 06:08 PM
NewsBot
Dec 3, 2014 12:30 PM
