Adjusting IAC Counts
Old Aug 28, 2002 | 01:12 AM
97 WS6 T/A Conv's Avatar
Post Adjusting IAC Counts
I recently installed a CC306, AFR Heads, 1.6 RR and a TPiS 58mm TB. Everything went fine with install and the car fired right up. TPiS suggests setting the IAC count between 30-40 and when logging on Datamaster records the IAC at 118. They also suggest setting the TPS to approx. .54 volts which was done but I can't figure out how to get the IAC down to where they suggest.
Also on Datamster it says that "Desired Idle" is set to 3188 RPM's. Now it doesn't idle near that much but could the Desired Idle setting have anything to do with the IAC counts as high as they are? Bryan at PCM4L did the programming and his idle is set to 875 RPM. The car idles around 1200 when cold. Then driving it it fell to about 750-800 on the verge of stalling then when I came back on the first test run it was idleing at 1200 again. I know it should idle higher when cold but it stayed up at 1200 after it was warm, then it would drop and rise again.
Any help? Thanks
Gary
My 97 WS6 T/A Convertible (1 of 463).
13.27 @ 104.25 (1.96)
Best MPH 105.99
292.8 HP 328.5 TQ all before H&C
M6, AFR 195 LT4 Heads, LT4 Intake, Rev Kit, CC 306, FLP LT's, Borla, GM 3.73's, Pro Mag 1.6 RR, TPiS 58mm TB, lots of small stuff.
Old Aug 28, 2002 | 01:28 AM
drop top steve's Avatar
Post
adjust the manual idle screw to get your 40 on the iac, then slot the tps to get .5-.8 volts. that desired idle sounds a little off.
Old Aug 28, 2002 | 08:47 AM
kmook's Avatar
Advanced Tech Moderator
Post
You might need to do the 'drill out' mod on the Throttle Body. Everyone i know down here has had to do it on a 58mm TB to get the car to idle right.
I searched but cant find the web page that had the instructions and pics, maybe someone else has it.
I will also get this over to LT1 Tech also since it doesnt really fit in Adv Tech.
Thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
New Project Underway :0
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
football4life
Oct 4, 2015 07:48 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tdigger9899
Sep 7, 2015 10:56 AM
