Adding Screw In Studs and Guideplates
Old Mar 13, 2010 | 05:17 AM
WS6 TA's Avatar
Unfortunately, I've always used self aligning rockers on everything I've messed with so I've never had to think about this before, but the current project looks like I'm going to use a biggish cam with some old school small block factory iron heads.
What machining is needed to install screw in studs and guide plates? I know that the tops of the stud bosses need to be machined flat, perpendicular to the stud bosses, but I can't seem to find consistent information about how much. I've heard everything from:
- taking off the equivalent of the height of the stud hex and the guide plate (that seems like a lot, it's probably over a 1/4", I'm worried that might not leave enough of the stud bosses)
- just cut the thickness of the guide plates off (that would leave the assembled height roughly that of the original boss + the stud hex, I'm not sure that will leave enough clearance for the rocker trunnion
- the other extreme end, as little as you need to get a flat/consistent surface (why they are labeled "machining may be required)- obviously, if i"m worried that "just the thickness of the guide plate" will not be enough, I'm almost positive that won't be enough.
What's correct? Is there some magic number that works? If I had a set sitting around already done, or a spare, similar assembled engine sitting around I could just measure/test fit everything, but I don't have either (I'm hoping to make it a weekend head/cam swap so I need to have them done before the engine is torn down).
Old Mar 14, 2010 | 10:17 AM
Revolutionary's Avatar
To figure out how much to mahine down you need to try to figure out where the rocker arm is going to sit on the stud and then take off however much material will allow the rocker to sit at that height and not run into the radius a the bottom of the new rocker studs. Typically I've taken off .300-.375 which would account for the thickness of the guide plate, the thickness of the hex flats and the radius of the stud bottom. Once you've removed the old studs and cut down the bosses just run a 7/16-14 tap straight into the holes as they are already drilled the correct size to tap. Be sure to run a bottoming tap down after the regular tap or you might not be able to get the new studs all the way in.
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
