? about LT1 block vs. old SBC block
Old Oct 20, 2003 | 03:03 PM
All_Z_Way's Avatar
What would be required if I wanted to use an LT1 block as a traditional SBC?
By that I mean... using SBC heads such as vortec's,carb intake and old DEI distributor.
I have a spare LT1 short block. I could sell it / trade it for a SBC or just use it. Ideas?
Thanks,
James
Old Oct 20, 2003 | 07:12 PM
Got-LT1's Avatar
I doubt you could use anything other than gen II heads on it due to revese flow cooling and a whole bunch of other differences.
Old Oct 20, 2003 | 07:32 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Ive read that heads can be modified to fit, but its really not worth the trouble.
Old Oct 21, 2003 | 08:43 AM
All_Z_Way's Avatar
Thanks for the help.
Next question though... Is the block that radically different regardless of the fast that it cools in reverse.
Say for instance.. I put a different water pump on and tried to flow it the traditional way.
It would be fine if Vortec head 96+ would fit the block.
Old Oct 21, 2003 | 07:29 PM
SnortinLT1's Avatar
Stock LT1 Heads Ported Are reallyu good. Get a carbed intake for LT1 from summit , get a carb and distributor. get the Electric water pump and your set!
greg
D1SC383LT4
Jan 26, 2015 01:41 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
squinn
Aug 4, 2002 01:06 PM
