700r4 problems
Old May 14, 2003 | 12:38 AM
1989gta's Avatar
700r4 problems
the first problem was that it takes a long time to shift from 2nd to third
it did this 8-9 hard runs under 150 shot, then on strait motor the tranny lets loose in 2nd gear only and now happens everytime in second.
The first time it happend it made a pop at about 3500 rpm and then went to 7000 grand in a second.
I put the car into gear and now it slides into gear like a cadillac.
it shifts fine from 1rst to 2nd and 3rd to 4th but will not hold 2nd all the time it's very soft not like when i put in the servos
i took the tranny out thinking it was the band but it looks okay. i can get as many pictures as needed.
i just don't know where to look.
i have a most of the parts from this site
http://www.transmissioncenter.net/700MegaRaptor.htm
sorry if i'm not clear it's almost one
any help would be great, were driving to chicago in 2 weeks
Old May 16, 2003 | 11:27 PM
1989gta's Avatar
found out the problem guys, the reverse input drum that the band connects to had a big uneven grove on it that started at the front and got deeper as it went back.
so naturally i'm over nighting the parts so i can be up and running on saturday.
Thank you very much ***********John from Master Transmission******** in Rosemount, Mn you guys are the best.
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
