5.565 rod length
Old Nov 28, 2003 | 10:25 AM
RUFFIDLNZ's Avatar
5.565 rod length
Has anyone heard of running 5.565 length rods? The reason I am asking is I bought a motor last year that was supposedly built by MTI and was a supercharged motor. I broke the motor down to refresh it with some new bearings and such and found out that it has the 5.565 Eagle H-beam rods and wondered if anyone has heard of anyone running these length rods or not. The motor also has a Callies Stealth lightweight crank but since whoever put this combo together they had to add quite a bit of weight to get the rod, piston combo to balance out. I am thinking about going with a longer rod and different piston combo since I dont see anyone running this short of a rod but I am asking you guys if there might be a reason why they went with this short of a rod on a 383 LT1 motor. Like I said above this motor was supercharged before but I will be going with a direct port nitrous kit and shooting around a 250-300 shot.
Thanks for any help guys.
Glenn
Old Nov 29, 2003 | 09:26 AM
OldSStroker's Avatar
It's deja vu...all over again, as Yogi said.
http://web.camaross.com/forums/showt...hreadid=197809
If you need to change pistons for compression ratio or because the bore needs a rebuild, by all means go with 5.7 or maybe 6.0 rods. If the current setup is sound, doesn't leak, and has a reasonable CR, and you are going for the 300 shot, perhaps you might try that before you rebuild, as you said.
Personally I wouldn't get all that concerned about the "400" rod length. The 300 shot would be of more concern to me.
My $.02
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
