350 block
Old Jan 26, 2003 | 10:03 PM
99huggerorangeZ's Avatar
Question 350 block
i have a 4 bolt main 350 block that uses bolts to attach the caps to the block but i want to replace them with ARP main studs
if i do will i need to have my mains aligned honed?
Old Jan 28, 2003 | 02:32 AM
Zero_to_69's Avatar
That's a good question. I know that it's recommended to hone
the rods and caps if you change the studs...I have never heard
of this for the main caps?
I would imagine it would follow the same rule as the rods?
I changed my main bolts for studs because of a windage tray
and I was not informed of this.
When I rebuilt my motor, I had asked if my mains should
be align honed when I had my cylinders honed. The tech
suggested it only be done if the main caps were mixed.
That doesn't answer "BowTie's " question, but maybe
someone could verify what the machinist told me as well?
T.I.A.
Old Jan 28, 2003 | 03:08 AM
SStrokerAce's Avatar
Well you can get away with either rod bolts or main bolts being changed and not hone wither one.
You can go to a ARP main stud and not line hone the block if it is good to start with. I would go with the windage tray versions and run a windage tray too. I do this for the studs strength and the ease of mounting a diamond screen windage tray to the engine.
Bret
Old Jan 28, 2003 | 10:25 PM
Question
so i can get away with not having to align hone the mains if i decide to replace my stock main cap bolts with ARP studs?
and if i do i want to get a milodon diamond windage tray will that tray work if i get ARP main studs for windage trays?
P.S. it is a brand new 350 block from the general(GMPP)
Old Jan 29, 2003 | 02:18 AM
1st question. Yes
2nd Question. Yes just buy a ARP stud kit for a 2-bolt block with windage tray bolts.
You should be o.k. with that block, esp since it's new.
Old Jan 29, 2003 | 01:41 PM
Post
i have a 4 bolt main 350 block not a 2 bolt
240ssLs3
Jul 13, 2015 05:06 PM
camaro02DK
Jul 5, 2015 09:04 AM
geinsteder
May 6, 2015 06:02 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
