350 or 400 mains
Old Jul 6, 2005 | 04:05 PM
  #16
1racerdude's Avatar
Re: 350 or 400 mains
Originally Posted by 69vette
dart block work out then?? Can you get the dart block with the bores not finished so that you can hone them to your specs...all the ones i see through summit have finished bores. With the raised cam, you have to run the diff. timing chain set up and do you run a shorter pushrod to compensate for the cam being higher? How much more is the raised cam set up going to run then a normal cam set up? thanks bret and everyone else
If ya had to get the accessories anyway for the LT-1,it would not be but $1-200 more and a screaming set up.
I would get the block that would let me go to close to a 4.150 bore or a tad less,with one more boring left to rebuild.
Those heads will flow ungodly if ya REALLY unshroud the valves.Don't let anybody tell ya .080 is enough,the more ya have the better the air column and more of it into the cyl.
Old Jul 6, 2005 | 04:50 PM
  #17
69vette's Avatar
the dart block can be bored to 4.185 maximum. Is there really much difference in boring it 4.125 or 4.150 for the first round? Seems like by boring it out to 4.150, you are limiting yourself to less rebuilds on the block. With the 4.125 it is a 427.43 cubic inches and with the 4.150 bore, you would have 432.629 cubic inch motor. You owuld gain about 6 cubic inches.
Old Jul 6, 2005 | 05:12 PM
  #18
1racerdude's Avatar
Only for valve unshrouding.Its not the 6CID.
Old Jul 6, 2005 | 05:49 PM
  #19
69vette's Avatar
So you think that unshrouding them that much more will make a huge diff. or is it going to be minimal?
Old Jul 6, 2005 | 05:56 PM
  #20
1racerdude's Avatar
The more ya have the better.I can't say that it would be a huge difference,but one overbore will last 8-10 years if ya don't blow it up.
Old Jul 6, 2005 | 06:02 PM
  #21
69vette's Avatar
Can you put a rough number on the differnce in hp so i can put it in perspective? Or does that all depend on ten million other things?
Old Jul 6, 2005 | 06:44 PM
  #22
1racerdude's Avatar
No
But I will site an example:
A guy had a 598?BB and made it a 640? with a .060 smaller bore and the rest in stroke. He used the same heads,cam,intake. The car was running 8.60's and slowed down .3 tenths.He changed cam's and that didn't help. He talked to other engine builder's and they all scratched their head.
We got to talking and determined it was valve shrouding.He bored it to the other block size and used the same style pistons,except .060 larger,and changed nothing else just to see.
The car went a 8.26 it's first pass after the bore job and has since gone quicker.
So valve shrouding IS important and everybody thought the bore size of that BB wouldn't shroud the valve, but it did. The extra few cubes didn't do it either.
Old Jul 6, 2005 | 07:30 PM
  #23
69vette's Avatar
Alright that def. puts it in perspective then. I didn't realize that the valve shrouding would be bad since the heads were originally set up for a 4.125 bore. I guess the last question in concern tot he block is should i keep it stock deck height or get the taller deck that dart offers? thanks for all the help.
Old Jul 6, 2005 | 07:38 PM
  #24
1racerdude's Avatar
Stock.The tall deck get's REAL expensive to make it do what it's suppose to do HP wise. Automatic new intake and header's and a bunch more.
Old Jul 6, 2005 | 07:50 PM
  #25
69vette's Avatar
www.summitracing.com part number DRT-31121211
so that looks like the block for the application then? wheres the best place to get it so i don't have to weight till august 16?
Old Jul 6, 2005 | 10:27 PM
  #26
SStrokerAce's Avatar
Originally Posted by 1racerdude
No
So the heads were cut for the big bore the first time? Make sense that he slowed down. OTOH you can make heads work on a smaller bore, al la LS1... only problem with those things is the heads flow like mad but make power like crap for the cfm. 330cfm should make 700hp if done right, not 550-600hp.
I'm still a fan of bigger bores. Actually a old GM engineer wrote in to Hot Rod about the Bore vs. Stroke story and told the tale of the "mystery motor" development and the shrinking of the 396 bore to use the common crank with the 427 and they lost HP on the motors, once they motored them to find frictional losses TA DA! there was all the HP losses... sometimes it's frictional losses sometimes (especially on BBC's it's bore shrouding issues)
Bret
Old Jul 6, 2005 | 10:55 PM
  #27
69vette's Avatar
so from your point of view bret, would you bore the motor over to 4.150" or just leave it at 4.125 and be able to get more life out of the block in case you need it down the road? Just trying to get everyones point of view. Also if you'll could post up some link for where to get the block and let me know if thats the correct part number. thanks
Old Jul 6, 2005 | 11:12 PM
  #28
1racerdude's Avatar
Bret
From looking at his heads the chambers didn't appear to have been laid back to the edge of the bigger bore. IMO it all had to do with the distance between the valve and the bore and I feel that was proven.
Got a first hand idea on what the 330CFM will make.That won't make 700 IF everything else isn't dead nuts.
Old Jul 6, 2005 | 11:24 PM
  #29
.060 on a bore is a big amount either way.... It would have been interesting to see the flow on the bench with both bores to see if there was a difference as well.
As for the LS1 heads.... they ain't gonna make 700hp out of 330cfm unless you spend lots of money on the R&D of the port... only a few guys out there that can do that too.
Bret
Old Jul 6, 2005 | 11:28 PM
  #30
1racerdude's Avatar
Bret
I was speaking my engine .
