2 series ?'s
Old Aug 9, 2002 | 12:26 AM
Carson 94 t/a's Avatar
Question 2 series ?'s
I dont know if it is approprate here but if i get the zexel diff http://www.slponline.com/view_produc...TNUMBER=64501T what would i need to put in 3.42 gears in my 2.73 rear.
tia
94 T/A t-tops, a4 !maf screen shorty headers !cat flows DIY CAI MSD 6al
nitrous works powerwing kit 125hp
Old Aug 9, 2002 | 07:21 AM
94 NO TOP Z's Avatar
Post
Need the 3-series carrier shown, a 3.42 gear set, and a gear install set (bearings, shims, etc), 2 quarts of gear oil, and one bottle of GM diff lube additive. If you are installing yourself you will need a dial indicator with magnetic base as a minimum. You will need someway to reprogram your computer for you speedo to work (Hypertech, LT1 edit, Tunercat, etc). I have seen a speedo recalibrater on the SLP site but, don't know how well they work.
Old Aug 9, 2002 | 01:37 PM
kmook's Avatar
Advanced Tech Moderator
Smile
This is more appropriate in the LT1 Tech section, moving now...
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
KamikaZ28
May 28, 2015 12:45 AM
May 1, 2015 01:14 PM
