'05 gt head flow numbers
Old Nov 29, 2004 | 12:52 AM
  #16
Boost It!'s Avatar
Re: '05 gt head flow numbers
Originally Posted by SStrokerAce
Well that explains it then.
The 4.6L 3V is still worse than a LT1.
is that 1 or valves?
in any event, they make more power than the LT1 stock with 20% less displacement . and like i said, under 5lbs of boost they make make an additional 100hp. they also have that stupid, i want to call a paper cat, in the intake duct crunching it for 5-10hp. motor i saw dynoed 309hp i think. 315hp out of a 4.6 liter...not too shabby.
the DOHC 4.6 are where its at though. my understanding is people go pretty damn fast on stock castings in those things
Old Nov 29, 2004 | 02:14 AM
  #17
SStrokerAce's Avatar
Still go back 10 years look at the first Northstar. Smoother, more power, more TQ, same cubes. 320hp in the XLR version.
A LT1 gets about the same RWHP as a '05 GT with less TQ. Once you get in the car HP per L means squat.
The cranks in those 4.6L's leave a lot to be desired as well they snap like twigs were a LT1 crank is pretty dam tough and essentially a 50 year old design.
Maybe I'm just bitter because we don't have F-bodies anymore and the Ford pony car doesn't come close to living up to the concept car appeal. Well that and a bunch of drag racing series and organizations to race Mustangs and we have close to nothing.
Bret
Old Nov 29, 2004 | 07:31 AM
  #18
Elysian's Avatar
The Cobra's run 12psi. Not 5. I'd be ashamed of myself if I was only making 400hp with 12psi. In the end, the only thing Mustang guys can argue is "horsepower per liter" or some other nonsense like that. From the factory - they have trouble keeping up with a 10 year old f-body. If we're going to talk about modifying Mustangs vs. Camaro's & Firebirds - it boils down to this: if you have enough money, you can make any motor do anything you want.
Old Nov 29, 2004 | 12:05 PM
  #19
Boost It!'s Avatar
1. last i heard they run 8, stock.
2. i'm not talking about a cobra, they are not blown GTs. thye are 6spd manual IRS DOHC 4V blown forged motors with reduced compression. a GT is none of those.
3. mustangs have a lot of advantages on camaros and vice versa. they both suck. pick your poison
4. mutang guys, at the end of the day they have a factory supercharged car. infact take "factory supercharged" out of there and they still have us beat
Old Nov 29, 2004 | 12:07 PM
  #20
Boost It!'s Avatar
Bret
bret. i'm not comparing mustang vs camaro. i'm just stating their heads make power.
Old Nov 29, 2004 | 01:20 PM
  #21
Elysian's Avatar
I stand corrected.
Old Nov 29, 2004 | 09:31 PM
  #22
I know they can make power, throw enough boost at something and it can make stupid power.
Hell a 2.2L Ecotec can make 975-1000hp with 30psi!
I have nothing against Fords, hell the 302 motor is a great drag motor (with Victor heads and a Dart Block) but I still can't get that GM out of my head.
Bret
Old Nov 30, 2004 | 03:24 AM
  #23
Boost It!'s Avatar
Bret
my point was they flow air well in order to make 300hp on a 4.6L and +400hp under 5lbs of boost
Im not a ford fan, at all. Just dont tell that to the guys at work concidering our racecars are ford based
Old Nov 30, 2004 | 10:39 AM
  #24
Elysian's Avatar
Forgive my ignorance of Ford products, but I am slightly confused: Are the 4-valve heads on the modular 4.6L interchangable with the 5.4L motor used in the Lightning & the GT40? My guess would be no. Is the block the same (i.e., small differences like those between LS1 & LS2 - bore size, sensor location, etc.) or radically different?
It is also my understanding that the modular 4.6L block accomodates 2-valve, single overhead cam heads (older Mustang GT's); the 4-valve Cobra heads; and now, the 3-valve heads on the 05 Mustangs. Yes?
Old Nov 30, 2004 | 03:10 PM
  #25
Boost It!'s Avatar
the only thing i am fairly certain of is 4.6 4V to 5.4 4V are interchangeable... i think. i might even be wrong about taht the more i think
Old Dec 1, 2004 | 10:10 AM
  #26
Ponyhntr's Avatar
I'm not sure on the 3-valve stuff, but the 4.6 will accept both 2-valve and 4 valve heads. The only difference between the GT and the Cobra Blocks (2-valve vs. 4-valve) is the main caps. The GT has 2-bolt mains, whereas the Cobra has 6-bolt mains.
Old Dec 1, 2004 | 10:22 AM
  #27
Boost It!'s Avatar
does ford use an alum block in the NA cobra suff/mach 1 stuff
Old Dec 1, 2004 | 12:25 PM
  #28
Ponyhntr's Avatar
Yes, all the Mustangs run aluminum blocks except for the 03-04 Cobras.
Old Dec 2, 2004 | 01:02 AM
  #29
Boost It!'s Avatar
mustangs!? or cobras?
Old Dec 2, 2004 | 08:07 AM
  #30
Ponyhntr's Avatar
Cobras are Mustangs!
Yeah, all Cobra's, Mustang GT's, and Mach 1's had aluminum blocks except the 03-04 Cobra's.
