wiring a carburated LT1 in a 1983 camaro
Old Dec 8, 2007 | 05:32 PM
FAT RAULLY's Avatar
i might be getting a LT1 motor but i dont know what year it is yet. i was wonder what i needed to do to wire it into my 1983 camaro z28. It's going to be carburated but i have no idea what i need to wire it up for my car. Also will a 700R4 work well with the LT1 motor.
Old Dec 9, 2007 | 09:34 AM
Dave89IROC's Avatar
if it is carburated and using the GMMP intake to use an old school distributor, it will wire the same as a regular small block, and yes, the 700R4 will hook up the same as on any carbed engine
Old Dec 9, 2007 | 01:11 PM
FAT RAULLY's Avatar
what is a GMMP intake? the wiring harness on the car right now was for the 305. so will it work for the LT1.
Old Dec 9, 2007 | 05:36 PM
Dave89IROC's Avatar
i meant GMPP
GM performance parts
this intake
http://store.summitracing.com/partde...t=nal-24502592
run a carb and old school distributor
Old Dec 9, 2007 | 06:17 PM
FAT RAULLY's Avatar
so my wiring harness will work the way it is? Thanks very much for your help.
Old Dec 27, 2007 | 11:37 AM
Army4life's Avatar
I could be wrong, but i dont think a 305 wiring harness will work for an lt1. Though, I am not very familiar with lt1 carb conversions, so I could be wrong.
Old Dec 27, 2007 | 04:45 PM
Dave89IROC's Avatar
it will work fine, the carb conversions use all old schools stuff, so, no issues
Old Dec 27, 2007 | 04:47 PM
Dave89IROC's Avatar
are you using an aftermarket carb? if yes, use an HEI dist, and then you just need to change the end on i wire, and it will run great
Old Dec 27, 2007 | 09:21 PM
Army4life's Avatar
Dave,
Really?? A First Gen computer can control a Second Gen motor? Thats just weird if ya ask me But you know your ****, so I'll take your word on it.
-Matt
Old Dec 27, 2007 | 11:12 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Why would you buy a late-model fuel injected engine just to throw an old-school carb on it? SBC's are a dime a dozen practically, why not use one of those? Keep the LT1 fuel injected. Not to mention the LT1 doesnt use a standard distributor so you'll need some kind of distributorless ignition, I think MSD makes them.
Old Dec 28, 2007 | 06:14 AM
Dave89IROC's Avatar
Dave,
-Matt
if you go carbed, then you will be running a carb and a old style distributor, so why would anything different be needed?
if he was going fuel injected, it would be a different story
Old Jan 2, 2008 | 04:55 PM
Army4life's Avatar
Eh it's just weird that a completely different generation motor can be controlled by a factory 305 gen-1 ecu
Old Jan 2, 2008 | 05:19 PM
Dave89IROC's Avatar
only real difference is the reverse flow cooling system and the opti
Old Jan 20, 2008 | 01:48 PM
Army4life's Avatar
sorry about the delay Dave, it's been tough getting to a computer to get on here. But I suppose that makes since, I thought there were more differences. Would a carb-converted ls1 be able to be controlled by a 305 ecm?
Old Jan 20, 2008 | 04:20 PM
Dave89IROC's Avatar
LS1 or LT1?
was it a carb car to start with? or TPI/TBI?
