will 2 bolt hold?
Old Feb 20, 2004 | 02:54 PM
STANGeatinZ's Avatar
will 2 bolt hold?
aight you all know what i've got 383 eagle kit no heads or cam yet, but my block is a two bolt main, i've already had it machined and the bearings installed. I've just started worrying about the strenght of the block. any opinions welcome.
Thanks,
Derrick
Old Feb 20, 2004 | 07:22 PM
formularpm's Avatar
Well, you left out the most important factor. How much power is it going to make? Its almost impossible to gauge exactly how much a given block can take, but given a well-balanced rotating assembly and some restraint on the redline, Id say you should be good to 500hp. This is just a ballpark figure, however, so dont take it as anything else. Id be sure everything else is strong before you worry about the block.
Old Feb 20, 2004 | 07:29 PM
Black6SpdTA's Avatar
That's the number I've heard. Although every block is different, that should be an acceptable ballpark figure. I've also read that 2-bolt's can be spun faster? No verification though, just word of MOUF
Old Feb 20, 2004 | 07:43 PM
rudy's Avatar
just toss the main bolts in the trash and use a stud kit. You'll be fine.
Old Feb 20, 2004 | 09:30 PM
Jids's Avatar
thats a fine idea as well.... ARP !!!
Old Feb 20, 2004 | 09:43 PM
aklim's Avatar
Well, that all depends. If you have sonic checked the block for core shift and did all the machining like you should, LPE will use a cast crank and recon rods for up to 500HP. I figure it can't be too bad because they give a 2 yr 24K warranty on it.
Old Feb 21, 2004 | 11:35 AM
i'm hoping to make at least 450 horses and a 150 shot on top of that.
Old Feb 21, 2004 | 05:36 PM
aklim's Avatar
For the shock value of the NO2, I would go with a 4 bolt or a 4 bolt splayed.
Old Feb 23, 2004 | 03:45 PM
that's what i figured i was just hoping i wouldn't have to b/c that is just more money i have to put in the block.
thanks though,
derrick
Old Feb 23, 2004 | 07:18 PM
SSnthe10s's Avatar
u should buy some splayed main caps. then take it to the machine shope and they will drill out the holes. splayed mains are hella stronger.
Old Feb 24, 2004 | 02:01 PM
bout how much do splayed caps cost?
Thanks,
Derrick
Old Feb 24, 2004 | 03:18 PM
oil pan 4's Avatar
$214 from summit, but you don't get a frount and rear cap.
Old Feb 24, 2004 | 03:56 PM
aklim's Avatar
Just ask the machine shop for the "splayed caps option" when they are doing your block.
Old Feb 24, 2004 | 04:31 PM
IROC-T's Avatar
I may be off base here ,but doesn't RPM's have something to do with this matter,seems I heard something about this awhile back and up to a certain RPM two bolts hold just fine,I may be wrong but is something to check out.
Old Feb 24, 2004 | 04:46 PM
trackbird's Avatar
Generally, a 2 bolt is good for 450-500 hp and about 6100-6300 rpm. Above that RPM, the main caps can "walk" in some cases causing funny things to happen to the bearings.
Oliver (as in Oliver connecting rods) makes billet front and rear main caps (and splayed mains as well) to work as a set. Or, GM used to sell a billet front main cap (and the rest if you need them. That is what I put on the 1995 block that I did with splayed main caps, Milodon mains and a GM billet front cap with ARP studs.
Again, these are "rule of thumb" numbers and can vary.
