whole mess of 3rd gen questions
Ram Air really depends on where you put it on the car, it must be in a strong positive pressure area. Meaning a Ram Air hood scoop is worthless if the scoop is in the middle of the hood. All of the air pressure skips right over it. It MUST be at the front lead edge of the car, like the newer TA's or in headlight locations or fog light locations. And if set up right, you can "stack" up air at speed. I'ts not near as good as a blower, but when the engine creates it's low pressure area or vacuum, the air will fill it more readily and completely, plus the air is colder denser air. So it will increase Volumetric Efficiency. And that always makes more power...how much depends on the motor.
http://web.camaross.com/forums/showt...2&goto=newpost
That is the ram air system I installed. Depending on the weather (temp, humidity) effects how much power I get out of it. I do not think I got a 70hp gain, I just think the car needs to be tuned before I start throwing big bolt ons at it, so that I can get the most out of each mod.
link brings me back here.
Regardless, I'm glad your car has responded
well. I just don't think that your mods are the
sole factor in cutting down your ET's so they
aren't a "how to" on getting 305's moving.
I had a 91 Z28 5speed myself and I wish I still
had it.
By the way, does your name come from
"the best band in the F'in universe"
had it.
had it.
had it.
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Dec 21, 2014 09:47 PM
stars1010
Jul 15, 2002 03:51 AM
