White Smoke at Startup
Old Jul 14, 2003 | 11:01 AM
88Irocker's Avatar
My 88 Iroc puffs smoke when I start it up, but its not blue, its white. Its also hard starting (unless it sits for a few days or more, then it starts right up). I'm wondering if it could have a leaky fuel injector? B/c if it leaks, it would be hard starting a few hours later with excess fuel in 1 or more cylinders. But after a week, it dries up and the engine starts up? Any ideas? Would leaky valve seals cause white smoke, or only blue?
Old Jul 14, 2003 | 03:29 PM
markzman97's Avatar
I think it is likely your rings causing the smoke at startup.
Old Jul 14, 2003 | 05:19 PM
mikey dragster's Avatar
it's moistuir in your gas,or your heagasket leaks when it sit's over night.
350 or the big bad 305.
it's a third gen be patent with it there old 80's car's.
they requir higher maintaince, and more tlc.
i'd run some 20w-50 oil ,and keep an eye on your oil level and coolant level.
closly monitor temp and oil psi.
it's prolly nothing.
Old Jul 14, 2003 | 06:36 PM
TheGreatJ's Avatar
That definitely sounds like a dirty injector that's not closing all the way. If it was rings it'd be oil smoke (bluish) and the same with valve seals. A minor head gasket leak is a possibility, but injector issues are more likely. Run a bottle or 2 of injector cleaner through it and see if it helps. You might also want to get ahold of a fuel pressure gauge and see if it's leaking down quickly when you shut the car off (pressure should stay up for 20-30 min or more) because that would indicate an injector leak.
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
frankrizz
Sep 23, 2015 04:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
