Where can I get a fly wheel for a...
Depends on whether that's a 383 crank or a modified 400 crank. If it's a 383 crank (internally balanced) then you can use your old 305/350 flexplate. If it's a 400 crank (externally balanced) then you need to find a 400 flexplate and have it balanced to the crank. If you get the 400 flexplate make sure it has the same number of ring gear teeth as your old one (53 or 68.)
Hold on, let's get your combination of parts. The main things needed to know are whether it's a one piece rear main block (L-98 or later LT-1 reverse coolant block) and whether it's internally or externally balanced (most 383s are externally balanced).
If it's a one piece rear main block and externally balanced (I think that's probably what we're talking about here) then there are only a few places you can find a flywheel/flexplate that will work.
jasonduaine
Jun 4, 2015 09:29 AM
NewsBot
Dec 17, 2014 02:50 PM
