whats the width on a 3rd gen rear?
Does anybody know what teh width on a stock 3rd gen rear end is. I wanna put a 8.5" 10bolt out of a snd gen in my 92 and i have a set of zr1 wheels i wanna run. So if its wider i might beable to get away with not running wheel spacer. I measured the 8.5 10bolt out of our 70 SS/RS and it came out to be 55" back plate to back plate.
Thanks for the help.
Re: whats the width on a 3rd gen rear?
Not sure on the backing plate measurements but a third gen diff is about 61-62" from axle flange to axle flange (the part the drum sits against)
What are you going to do about the torque arm?
well for a TQ arm iv thought about using these and i have heard of other doing it too.
http://www.jegs.com/webapp/wcs/store...1177&langId=-1
You think a bolt on clamp around the axle can handle the rotational forces of the diff? Those don't eliminate the torque arm and they don't do any more than a set of LCA relocation brackets will do.
Installation instructions.
http://go.mrgasket.com/pdf/21700.pdf
If i welded them to the axle tubes they woudl serve the same purpose as a TQ arm. I have to do it some way. There is no good way of hook a TQ arm up to a 8.5" 10 bolt. and im not gunan spend mega bux on a 9" or a 12bolt when i can make somthing work just as good. Im not scared at all of a little fabrication.
Strange engineering but there's nothing on their web site about it yet.
http://www.strangeengineering.net/
Apparently it's about $2300
I wouldn't mind a Dana 60 but even for my car it's overkill.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
