what's going on
Old Feb 12, 2004 | 09:15 PM
nightrider's Avatar
what's going on
my winter car just took a crap. i was driving it down I-65 and it wouldn't go any faster than 55. if i gave it more gas it just bogged down. next i looked in the rear view and saw white smoke, then it died. came back a few days later, started and it idled REALLY rough. finally after about 1 minute, it died and the dip stick shot up about 3 inches. tried again and got the same thing....but no white smoke. any ideas?
at first i thought head gasket, but now i'm not so sure.
any help would be greatly appreciated.
Old Feb 12, 2004 | 09:48 PM
97WS6SCharged's Avatar
I'm not sure about shooting the dipstick up, but it does sound like a head gasket. Is the radiator missing any water?
Old Feb 12, 2004 | 09:52 PM
nightrider's Avatar
actually, i didn't look at the coolent level, but i did check the oil and it was a quart low....and also smelled 'burnt'
....i've never heard of the dip stick shooting up tho
Old Feb 12, 2004 | 10:05 PM
aklim's Avatar
On my 89 Merkur, when the crankcase was pressurized by an bad PCV it caused the dipstick to shoot up and spray oil all over. However the XR4Ti is a turbo car and yours is not therefore I would suspect that a head gasket or something is leaking. What does the oil look like? Take a compression test.
Old Feb 12, 2004 | 10:10 PM
nightrider's Avatar
the oil is extremely black
Old Feb 12, 2004 | 10:20 PM
aklim's Avatar
Does it smell of gas? Also I would run a compression test. Do you have a gauge? I can lend you mine if you need to. On the condition that I can find it first.
Old Feb 12, 2004 | 10:33 PM
nightrider's Avatar
no, it didn't smell of gas and i don't have a gauge. it sucks too because the car's 20 minutes away and i gotta bum rides to get there
Old Feb 12, 2004 | 11:13 PM
WhiteWhisper's Avatar
white smoke = head gasket
Old Feb 13, 2004 | 12:52 AM
IROC-T's Avatar
YEP! Head gasket..
What kind of car is it,you said winter driver so it's not an F-body,right?
Old Feb 13, 2004 | 01:02 AM
nightrider's Avatar
it's an 85 chevy celebrity. would a head gasket cause the dip-stick to shoot out???
Old Feb 13, 2004 | 01:46 AM
Irocvette355's Avatar
In theroy it could...the crankcase could have filled up with a mixture of coolant and oil. Thats one route the mixture would vent.
Old Feb 13, 2004 | 06:59 AM
greezemonkey's Avatar
what`s happened to your car is this one of your pistons has developed a hole in it or the ring lands have broken off the piston this will put oil in the combustion chamber and create white smoke
little oil burning =blue
lotsa oil burning=white
dipstick popping out=compression in the crancase(hole in piston)
Old Feb 13, 2004 | 10:28 AM
aklim's Avatar
Buy yourself a compression tester and try it out. If you are careful, you might even be able to return it.
Old Feb 13, 2004 | 03:12 PM
Marc 85Z28's Avatar
85 Celebrity? 2.5L "Iron Duke" 4 cylinder by any chance? They are known for cracking the cylinder head... Just a thought. White smoke is coolant in the chambers 99% of the time, and a cracked head and/or a head gasket is the most likely cause.
Old Feb 14, 2004 | 11:38 PM
nightrider's Avatar
thanks for all the posts. i think i'm going to have it towed to my house and tear into it on one of my breaks...but i will definately get a compression tester and let you know what i find.
