what year?
Old Feb 8, 2009 | 01:39 PM
alecracing's Avatar
what year?
did they start putting the L98 TPI engine in the Camaro??
Old Feb 8, 2009 | 06:09 PM
mako350Z28's Avatar
1987
Old Feb 8, 2009 | 06:12 PM
alecracing's Avatar
is it the same engine as in the corvette? intake and everything?
Old Feb 8, 2009 | 07:57 PM
rik89gta's Avatar
No. The Corvette 350 has aluminum heads and the f body 350 has cast iron heads.
Old Feb 19, 2009 | 11:27 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
The runners and plenum are the same. The intake manifold is different only in that the Corvette aluminum heads have the 86 and older style intake bolt pattern, while the 87+ f-body has the four center bolts in the intake manifold at a different angle (72* vs 90*). Also, the Corvette routes the EGR gasses from the exhaust manifold to the port on the passenger side rear, while the f-body gets the gasses from the cylinder head. Both intakes flow the same. Also the Corvette L98 and the f-body L98 have the same camshaft.
Old Feb 20, 2009 | 10:24 AM
Z28SORR's Avatar
One other small difference, on earlier Vette's there was a 9th injector, called an enrichment injector, for starting and excellerating.
Old Apr 13, 2009 | 12:34 AM
Kevin91Z's Avatar
The 9th injection was on 85-88 TPI engines, and was absent on 89-92 TPI engines. Its sole purpose was to shoot extra fuel into the engine for a couple seconds while starting, when the outside temp was less than 40* F. It was only controlled by a temp sensor on the front of the intake manifold, not by the computer. It did not provide any acceleration enrichment.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
meissen
Jun 1, 2015 07:59 AM
capebuf
Jan 13, 2015 07:22 PM
ChrisFrez
Dec 28, 2014 02:25 PM
