what would be idle for me?[406]
What would be an ideal Header for me?[406]
I think I have my mind set, but I would just like some input from others.
I'm finishing up my stroked 406 that'll be going into my 84 Trans Am(details at my cardomain, check it out)
anyway I got afr 210s, big ports. I need some "big" headers
1 3/4 or 1 7/8 Full tubes prefered
ultimate plan is a pair for super comp hookers that are 1 3/4
anyone know of a good header that maybe 1 7/8 or will the hookers be enough?
EDIT: I also plan on doing 2 straight pipes back to chambers ending before the rear axle with this setup...
For now untill I get more money I have slp shorties which are 1 3/4 that I picked up cheap.
Re: what would be idle for me?[406]
I think the Hooker Super Comp's would be fine for you at 1 3/4", but there are some Hedman Hustlers that are PN 65170(at least from Jet Hot) these have 1 7/8" primaries, and a 3 1/2" collector, Hedman also has a set with 2" primaries thats PN 65180. Both part numbers are from Jet-Hot, they may be the same from Hedman as well...but I can't remember because its been a long time since I looked them up for the old formula.
autoxr166
Sep 25, 2015 04:21 PM
