What timing chain to use?
Old Mar 15, 2003 | 04:50 PM
IgorT.455/406's Avatar
Hey guys. If I am going to put a LT1 cam in a late model roller block, all I need is a double roller timing chain FOR a late model block, and there should be no interferance problems with the chain rubbing on the block or timing cover, right? Thanks.
Old Mar 16, 2003 | 01:29 AM
Matt87GTA's Avatar
You are correct. As long as the timing set is for 87-up non-LT1 OEM roller applications it will work fine. You may have to push the alignment dowel in a bit on the LT1 cam but it will function fine. GMPP sells a very affordable single roller HD timing set as well that comes with all new bolts and a thrust plate and bolts.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
