What should I tell the guy?
Old Feb 20, 2004 | 08:55 PM
Wishmaster's Avatar
Im going tomorrow and have a guy make me a custom chip for my car....anything important that I should tell him? I have not run it on any diagnostic software but he did say that when I do he will update it to whatever the data reads..but till then anything I should let him know or anything in paticular that should be done... its an 87 TPI 305 2.73
here's what I have done to the car..dont pay attention to my old sig...
All Free mods, well we all know nothing is free....
Sealed Ram Air Boxes "Fogs removed", Ported Plenum, LT1 cam, 1.6rr's, SLP Tri-Y headers coated, 160 fan switch and stat, Holley AFPR, MSD ignition mods, Underdrive Pullies 3-set , Boush Platinum +4's, smog crap removed...
havent drove it yet still working on it!
Old Feb 20, 2004 | 09:50 PM
aklim's Avatar
Who is this guy? How much and how custom? Is he going to just burn you a chip for the car based on your mods? When I had mine done, Lingenfelter drove the car and had his assistant take readings, burnt the chip and redid the driving. Someone else I know will strap in on the dyno and do it and someone else would take engine readings and do it. Bottom line is it takes more than one shot unless that person is real lucky.
Old Feb 20, 2004 | 10:01 PM
Wishmaster's Avatar
the guy is a friend of a friend......custom as in not from any of those mail order places......Yeah I assume he is just going to go by what mods I have done to the car as I dont have any way of recording any data for it and dont have and have no idea how to burn my own.
But I will purchase the cable so I can record data with one of those programs and then I can just bring my chip back and have him burn it from the data I have.
With that said I assume the chip will be better than using the stock chip..right?
Old Feb 20, 2004 | 10:14 PM
aklim's Avatar
Yes, it will be better but not perfect. BTW, when I dropped my car off to LPE, they had cut a hole in my header, welded a bung and used a second O2 sensor to get readings just to fine tune the thing to make it perfect.
Old Feb 20, 2004 | 11:38 PM
97WS6SCharged's Avatar
They were probably using wideband O2 sensor to get the best readings from the car.
Old Feb 21, 2004 | 01:11 AM
aklim's Avatar
Whatever he did, it worked out just fine. It took a week for them to get it right. I'm sure the actual work time was a lot less.
Old Feb 21, 2004 | 02:46 AM
kandied91z's Avatar
it's true that the best way is to have the car in hand so you can make changes on the fly...or as close as possible with our damn computers. all engines can benefit from a proper tune but i don't really see anything in your list that requires a major overhaul. maybe just going through the stock program changing slight things here and there which should still make a slight difference.
this is a big reason why mail order chips are a problem as everything is different with each motor and it really should be handled with the car on site. there are some very interesting pieces of equipment that are just coming out though that will allow those who know what they are doing to alter the chips while driving which will cut tunning time down on our cars a great deal.
good luck with everything, i hope it works out for you.
Old Feb 21, 2004 | 10:35 AM
aklim's Avatar
You can use the ACCEL DFI system and all you need is to have your laptop plugged in and you can go from there.
Old Feb 21, 2004 | 12:28 PM
ZWILD1's Avatar
I've been considering this route for a little while. Basically you plug a "prom simulator" into the prom socket of the ecm. The simulator connects to a laptop, and from that point on the ecm reads values stored on the laptop. This means you can make running changes and immediately diagnose their effect. When you're done you need to burn only one prom.
Guess, when the new motor is done I'll look into it again. Should tie me over until I can afford the FAST controller I really want.
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
