What happens if I don't plug the header where the air pump vavle is suppose to be?
Old Oct 15, 2003 | 08:33 PM
BLACK Z !'s Avatar
Hi, I was just wondering what would happen if the air pump hook up on the header was not plugged or capped after taking the air pump off?
Old Oct 15, 2003 | 09:04 PM
mrr23's Avatar
did that one myself. caused the o2 to read way lean. headers ended up glowing. get some rubber end caps to put on them. 3/4"
Old Oct 15, 2003 | 11:26 PM
stk350's Avatar
cut it off and weld it, or pinch it shut and fold it over.
stk350's Avatar
Old Oct 16, 2003 | 04:19 AM
Brit Iroc's Avatar
Took mine down the local plumbing shop and he found some plugs that screwed straight on!!
Old Oct 16, 2003 | 09:32 AM
BLACK Z !'s Avatar
I have the plumbing caps on mine and we welded them shut and another car I was justing wondering since I work on cars once in awhile what would happen if we did not close them port ( if it would burn a vavle or not).
Old Oct 16, 2003 | 09:37 AM
aklim's Avatar
I use plumbing caps not rubber. Letting air in there gets contaminates the exhaust stream and makes it look lean and then the O2 sensor will tell that to the ECM and the ECM will dump gas. Excess gas. If you plug up the driver side, you will be fine. If you don't, you will have problems. The pass side has no effect.
Old Oct 16, 2003 | 09:57 AM
BLACK Z !'s Avatar
Why only the drivers side and not the passenger side? thanks
Old Oct 16, 2003 | 10:02 AM
aklim's Avatar
Unless you have modded your car like one of the members in this sub-board, you have 1 O2 sensor and that is in the driver side where the tubes all collect so as to get a general reading as to what that bank is doing. From there, assuming all things are equal, the ECM will use that and infer what the other bank is doing.
Old Oct 16, 2003 | 12:34 PM
Marc 85Z28's Avatar
When I removed my AIR system I had Edelbrock's TES on the car. The driver's side header AIR connection was creating a horrible exhaust leak. The car ran really rough (probably due to O2 readings), and the exhaust system had afterfire like crazy.
Old Oct 16, 2003 | 02:35 PM
Z28James's Avatar
off topic...but do you have any pics of your car? id love to see a 3rd gen painted electron blue. how much did it cost for the paint?
Old Oct 17, 2003 | 03:14 PM
Marc 85Z28's Avatar
Click here for link to another post with links for pictures. You'll see my reply about 1/3 way down.
Upper is 2002 Corvette Electron Blue with 2002 GM Sebring Silver GFX. The GFX match the wheels almost exactly.
Cost? $625! I work for a Lincoln/Mercury dealer and had it done at our bodyshop. Professionally painted for $500 labor and $125 materials. Most of the prep I did myself like removing emblems, lights, and minor things. The bodyshop guys popped out a few dents, repaired a couple of areas that were beginning to corrode under the old paint and removed as much old paint as they were comfortable with. Looks fantastic (pictures suck), every bit as good as a new car. AND it's still under our dealer warranty.
Old Oct 18, 2003 | 11:26 AM
Z28James's Avatar
yeah id say that does definatly look nice. my car has the RS hood and i was thinking about just buying the 91-92 blisters. did you buy yours seporate or actually find a 91-92 hood? how much did that cost?
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Aug 16, 2002 10:03 PM
