what does this wire connect to?
Old May 17, 2005 | 03:23 PM
Camaro_Boy's Avatar
hey, i know where the accual connector connects to under the dash but i cant seem to find where the colorful wires come from / what they controled? as well my window wipers have stoped from working if i hit the button for the washer fluid it will then wipe.. but only iff the washer fluid is coming out.. is there a hidden place that these connect to turn on the wipers? or are they for something completely else?
regards
Douglas
http://www.geocities.com/douglaswhiteing/DSC00800.jpg
Old May 17, 2005 | 11:44 PM
V8Rumble's Avatar
Re: what does this wire connect to?
Not entirely sure what you're referring to. You might have better luck/get better responses if you could give a bit better description...
Old May 18, 2005 | 03:41 PM
Camaro_Boy's Avatar
sorry about that, yes ok , so the accually white connector on the left plugs into a connector underneath the dash by the brake pedal.. however the other side of the cable. the 4 wire colorful one i must of pulled 2 hard and it broke off.. has anyone ever seen this cable b 4? and knows what it connects too? regards DOuglas
Old May 18, 2005 | 08:23 PM
Dave89IROC's Avatar
that is for cruise control, and cruise control only, although it does route near the wiper switch, so, you may have damaged the wires for that, you should first check the terminals at the motor for the right signals, if those are wrong, then you can open the column up
Old May 18, 2005 | 09:23 PM
Camaro_Boy's Avatar
thanks alot, today i was looking at it. and i connected to wires for the wipers backwards yes.. ill admit im a dumb *** for this.. and yes u were right they are for the cruise control... as well when i was taking apart the sterring column .. a clip that is in place to hold the high beam bar down fell off.. i cant seem to fix it now lol.. so more surgery to do.. thanks forthe help...
regards
Douglas
Injuneer
Dec 15, 2014 09:36 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
