What does Liters mean?
Old Jun 24, 2003 | 02:27 PM
Black6SpdTA's Avatar
I know that 1 Liter = 61.024 cubic inches but what, exactly, is "Liters" referring to? Thanks
-Rippin
Old Jun 24, 2003 | 02:29 PM
dewey316's Avatar
are you talking abotu like 5.0 liter, and 5.7 liter. ???
if so it is refering the displacment of the engine.
Old Jun 24, 2003 | 02:33 PM
Yea, that's what I mean. It's hard to explain though.
Cubic inches = Bore x Bore x Stroke x .7854 x Number of Cylinders
Why would they have CI and Liters if they both only meant the size of the motor? Does the amount of liters refer to how much of something the engine can hold? Other than CI/Liters how do you calculate liters?
Old Jun 24, 2003 | 04:55 PM
RedIrocZ-28's Avatar
Whats your question? 5.7L is how much water could fit into the bores if the piston(s) was at BDC and the head gasket and head are on the motor.
350 cid is 350 cubic inches of displacement (volume)
Old Jun 24, 2003 | 05:12 PM
Sitting Bull's Avatar
Litres is the Metric system's unit of measure for volume, based on units of 10.
The US will eventually migrate itself entirely over to metric and dispense with the Imperial measurement system, which is not based on any consistent number. In fact, a yard (or three feet) evolved from measuring half the distance of the king of England's arms held out from side to side. Other measures were similarly concocted. Pretty scientific, eh?
Old Jun 24, 2003 | 05:15 PM
That's exactly what I was looking for! Thanks
Old Jun 24, 2003 | 08:14 PM
TheGreatJ's Avatar
Liters is that, except metric. So is cc's for that matter (bikes and sea-doos and such.) 61.xxx ci=1 liter=1000cc's
Old Jun 24, 2003 | 08:24 PM
jms's Avatar
jms
Cubic inches are not figured considering the head gasket or cylinder head volume.
Example: a 3.48 stroke and 4.00 bore small block Chevy is generally considered to be a 350.
If the 350 had smogger 76cc heads and thick head gaskets, it is still the same cubic inch engine as if it had a 58cc head and thin head gaskets, even though the smogger heads would have a few cubic inches more total volume.
jms
Old Jun 24, 2003 | 09:09 PM
96cam4ro's Avatar
Personally I think Celcius is much better than Fahrenheit..0 for freezing and 100 for boiling as opposed to 32 for freezing and 212 for boiling..
Finding sockets for the metric bolts (10mm, 12mm) are also WAY easier than finding those crappy standard sizes (1/2, 3/4, 9/16).
Old Jun 25, 2003 | 08:08 AM
teke184's Avatar
if you really want to get technical...the comment about "the amount of water a cylinder could hold" is not very accurate...
that measurement would change depending on the temperature of the water...ie...expansion/contraction of matter. water has a unique property in that as it approaches the freezing point, it expands.
if i remember my conversions
Old Jun 25, 2003 | 09:09 AM
dewey316's Avatar
it actualy expands as it freezes, because it forms a chrystalus structure.
IndyZman
Oct 22, 2015 02:17 PM
NewsBot
Sep 14, 2015 09:20 AM
jerrysims71
Aug 15, 2015 12:47 PM
Rittmeister
Aug 7, 2015 01:13 AM
