what do you think this would run??
Old Mar 2, 2004 | 08:12 PM
z28droptop's Avatar
991 rs 305 automatic with 125,000miles. Transgo shift kit, 2800 stall, performer rpm intake, switched tbi to carb, open element filter, world products torquer r/t heads, headers, 3 inch exhaust no cat to flowmasters, lt-1 cam, 4,10 gears, and subframe connectors???? what do u think it would run in the 1/4 mile??? thanks alot. Do you think i would need nitto's???
Old Mar 2, 2004 | 08:41 PM
Marc 85Z28's Avatar
High 13s around 100 assuming good traction. That cam is holding you back.
Old Mar 2, 2004 | 09:04 PM
z28droptop's Avatar
I dont have this car i was really thinking of buying it and doing this to it. What cam would you suggest?? Also what would you estimate all that would cost if i did all the work except the shift kit?? thanks alot
Old Mar 2, 2004 | 09:43 PM
dj haf's Avatar
i dont think you'd touch 13's in that... i'd say low 14's
Old Mar 3, 2004 | 03:10 PM
z28droptop's Avatar
What would you guess all that would cost?? thanks alot
Old Mar 3, 2004 | 03:19 PM
dj haf's Avatar
buy yourself a 90-92 iroc/z28 for around 4k and mod it up yourself... dont get something someone's already dicked with
Old Mar 3, 2004 | 07:30 PM
1986z28's Avatar
Old Mar 3, 2004 | 07:51 PM
greezemonkey's Avatar
same as above
Old Mar 3, 2004 | 08:28 PM
Marc 85Z28's Avatar
I still say 13s are easily attainable if you put the power to the ground with some sticky tires.
That combo should have no trouble putting out around 275-280hp - possibly more.
Last I checked 275hp + nice stall and gears + good tires = 13s
Old Mar 3, 2004 | 08:51 PM
dj haf's Avatar
it's a 305 automatic... with a lot of milage on it...
i saw a 350 tbi with lt4 cam, afr's, 2500 tc, headers, and flows pull a 15.8 and then a 16.1 while i was at the track... guy took it there for the first time thinking it was going to run low 13's. i wouldnt buy a car that's been worked on... i'd only buy a car that's completely stock and looks like it's never been ragged on.
once you buy that car, you'll realize why they sold it.
buy yourself some type of car with a 350 in it... 305 auto's are sh*t... the manual 305's were low 15/high 14 second cars, stock.... depending on the driver
Old Mar 4, 2004 | 01:56 PM
Marc 85Z28's Avatar
It's not just a "305 automatic". It's got heads comparable to Vortecs, and decent cam (for a 305), full exhaust and a nice intake with a good converter and gearing to complement the engine. As long as he isn't BSing about the mods, even in rough tune that engine should have no trouble cranking out over 250HP.
And I've seen an LS1 C5 run 15.5, 15.9, and 15.1 all in the same night, back to back to back. What's your point? It wasn't the car's fault.
Old Mar 5, 2004 | 11:25 AM
Slush92RS's Avatar
I'm going to guess maybe mid 14's, if you are lucky!
Old Mar 5, 2004 | 01:45 PM
Ray86IROC's Avatar
CHP or CarCraft did a similar buildup with a LG4, it made like 300hp with the S/R Torquers, but with a hotter cam (XE262 218/224 dur @.050, lift of .462/.469).
Vortec heads made 25 hp over the S/R Torquers on this engine btw with no other changes, pretty big increase...
It's not just a "305 automatic". It's got heads comparable to Vortecs....
I'd give ya low 14s in this car... Pretty sad seeing as you could start with a decent 350 TPI car and already be there...
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
