Valve Lift Queston
Old May 14, 2006 | 03:25 PM
Irocvette355's Avatar
Valve Lift Queston
im going to be putting in the LT4 hotcam with 1.6 rr's
I have the Aluminuim L98 heads...double valve springs w/SS valves
Is .525 too much lift for these heads?
Old May 14, 2006 | 03:54 PM
91Z-28's Avatar
Re: Valve Lift Queston
As long as the valve springs you bought are sufficient for .525 lift, then your only issue should be whether or not they fit in the spring pocket.
Old May 14, 2006 | 06:16 PM
respectirocz's Avatar
what is your install height and coil bind of the springs?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
centric
Aug 15, 2002 09:04 PM
