Upgrading rear-end
Old Sep 26, 2003 | 11:14 AM
85_LG4
Guest
Posts: n/a
Upgrading rear-end
Ok.. so I am plannin on buying a Torsen T2 rearend..
I relize that I will be needing 28-spline axles.. but what about everything else?
What about brakes.. won't I need new ones? Could I just rip the disc (my car currently has drums on it) brakes off of the car I get the 28 spline axle off of, and just use that? They will bolt rite up to my car, rite?
Anything else I will need to change over?
Thanx everyone,
Matt
Old Sep 26, 2003 | 12:12 PM
teke184's Avatar
Torsen T2 isn't familiar to me...
is that just the differential...as in the posi unit?
why not just look around for a camaro in a junkyard that has what you want.
all the Z28's and Trans-ams will have posi units and should bolt up to everything...brakes, ebrake, shocks...everything
being 16 i think it would be a better more cost effective way to get it on the road.
Old Sep 26, 2003 | 03:02 PM
StealthElephant's Avatar
find a 9 bolt
Old Sep 26, 2003 | 10:34 PM
85_LG4
Guest
Posts: n/a
Not all Z-28's have posi.. mine doesn't..
The Torsen T2 is a posi differential unit.. used in like.. 89 'Marrow's (I believe.) and in like '93-present Camaro's.
Plus, the local j/y's have ****ty-assed rearends.. like ****ty gears, drum rears, etc..
9-bolt? What did they come on? How much they cost? Where could I find one?
Old Sep 28, 2003 | 01:12 AM
jayman350's Avatar
you can swap in a 4th gen rearend and all you have to do is change the proportioning valve so that the disc brakes will work
I did this about 2 months ago, i love having posi, disc brakes are SOOOOO much better than drums, and the rear ends are very available and came w/ a bunch of different gears
Old Sep 28, 2003 | 08:48 PM
85_LG4
Guest
Posts: n/a
How much should a 4-gen rearend cost? How much is a prop. valve?
Old Sep 28, 2003 | 08:53 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I need to get a 12 bolt or a 9 in for mine. Im afraid to start looking at prices though
Old Sep 28, 2003 | 08:55 PM
85_LG4
Guest
Posts: n/a
Lol.. same here!
Old Sep 28, 2003 | 11:24 PM
jayman350's Avatar
i ended up spending a little more than i should have on my swap but here's how it broke down for me
$300 for rear end
$160 for brakes and misc other parts
$30 for prop valve and new brake booster
i've been told that people have gotten complete rears w/ brakes for around $3-400 so it just helps to look around, no one that i talked to had brakes on the rears around here so i was kinda stuck
everything bolts in exactly how it comes out, the rear end is just a little (4 inches) wider than the 3rd gens.
good luck
1986MCSS's Avatar
The 9 bolts came in some 3rd gen f-bodies, not many though. Iroc's, GTA's and formula 350's are the most likely to have them. I just bought an 88 formula from a guy about 2 months ago for 1500 bucks. I really lucked out on this baby, it has 4 wheel disc brakes, the borg warner 9 bolt rear end, 350 tpi, and an aluminum driveshaft. I thought there was some chance that it was a 1le package in a formula, but it only has single piston calipers on the front, and there is no 1le rpo code, oh well.
Old Sep 28, 2003 | 11:25 PM
doug791's Avatar
i swear i saw a complete moser rear end ready to be bolted up for 2100? not TOO bad but not great either.
Old Sep 28, 2003 | 11:53 PM
DarthIROC's Avatar
I said I was afriad to look and then you show me the horror And that is a decent price that what scares me.
I think Ill just put the 427 + TH-350 combo together with a posi 10 bolt I have. Just to see how long a stock 10 bolt will hold 600+ ft/lbs of torque. Then I will get a real rear end
Old Sep 29, 2003 | 08:51 AM
Hopefully when the 10 bolt goes it doesn't take expensive parts with it
From what I've seen 2k is pretty much what your gonna pay for a 12 bolt or 9"....seems like trying to convert a different 12 bolt or 9" to fit a 3rd gen will end up costing the same and being more work.
Old Sep 29, 2003 | 07:08 PM
doug791's Avatar
sorry about that but yeah 2 grand doesnt seem TOO bad just because the chances of ever wrecking it are slim to nil....and then possibly still on the other side of nil. I agree it is expensive as far as things go but you also have to realize what a huge component of your drive train it is.....in retrospect how im ever going to save up for one is still beyond me but oh well.....
Old Sep 29, 2003 | 07:15 PM
DarthIROC's Avatar
Im gonna go outside, and start working on being able to drop my rear end in like 5 minutes.
Then Im gonna go to the drag strip, find a 3rd gen that already has a 9" and pull his before he notices and be gone with it
Then its just a matter of switchin in teh ratio I want. Im looking at 4:88's I think Im gonna go with them.
