Trying to Replace Power window Motor
Old Nov 5, 2003 | 12:04 PM
toneyb35's Avatar
I'm having a hard time trying to replace my passenger power window motor on my 91' vert. It looks like the motor and regulator has to come out in order to replace just the window motor. Please help. Thanks guys and gals in advance...
Old Nov 5, 2003 | 09:29 PM
Garage Inc.'s Avatar
Try this out..
I know your not doing a manual to power window swap...but it should show you how to replace it anyway, you know?
http://www.p71interceptor.com/thirdgen/powerwindows/
hope this helps somehow
Old Nov 5, 2003 | 10:50 PM
LandryP's Avatar
Yup the regulator has to come out. You have to undo a couple 10mm bolts and drill out the 4 rivits that hold the regulator/motor assembly into the door. Be careful when you seperate the motor from the regulator, that spring is visious (I think theres a spring there its been a while). When you put the regulator back in you can use rivits or 1/4-20 bolts, Ive never had luck trying to put bolts in and end up borrowing the masive riviter that looks like a pair of bolt cutters
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
MilkyClr69
Jul 29, 2002 10:01 AM
