trans swap kit
Old Feb 12, 2004 | 03:30 AM
udlooz's Avatar
trans swap kit
Does anyone that has done the 700r4 to 350th trans swap know if the kit you buy from summit/jegs can be used with a 350 with the longer 9inch shaft(so i wont have to get a new driveline). im thinking there might be a problem depending on where that torque arm bracket bolts to on the trans??
Old Feb 12, 2004 | 05:33 AM
greezemonkey's Avatar
Yea, I don`t think the tail shaft length would make a difference, the mount bolts to the trans where the tail attaches so the length should`nt matter. You will need a custom driveshaft though, if you use a 3 inch tail th350 you can use a stock 200 metric drive shaft, that might be hard to find nowadays though...they only came with that trans till like 84 or something
Old Feb 13, 2004 | 12:49 AM
udlooz's Avatar
cool as long as it bolts on where the tail attaches it should be fine and my driveline should work becuase i am going to use a longer tailshaft. thanks
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
