which trans cable can i use?:confused:
Old Mar 12, 2004 | 12:56 AM
z91bowtie's Avatar
Whats up guys? question i'm getting ready to swap my tpi 305 with a lt1. and i want to know about the trans. i have in it now a 5 speed and the lt1 came with a 4l60e trans so i want to know which cable do i need. 3rd gen or 4th gen? also if i use a stock 3rd gen shifter will i need the 4th gen cable and will this work together if thats the case? i would try using the 5 speed but from what i've read it's not strong enough. thanks for any help.
Old Mar 12, 2004 | 02:17 AM
aklim's Avatar
Are you talking about the cable that goes from the shifter to the tranny (4L60) or are you talking about the kickdown cable?
Old Mar 12, 2004 | 02:28 AM
97WS6SCharged's Avatar
The 4L60E doesn't use a kick down cable. As far as shifter cable goes, either should work.
Find a 6 speed and you'll look like this...
Old Mar 12, 2004 | 10:59 PM
z91bowtie's Avatar
I'm talking about the one for the gears
Old Mar 12, 2004 | 11:01 PM
z91bowtie's Avatar
If i had enough money you bet your *** i would buy i 6 speed
Old Mar 12, 2004 | 11:10 PM
aklim's Avatar
I don;t think there is a cable for the rear end gears. For the 4L60, it has a kickdown cable and a shifter cable and a speedo sensor. For the 4L60E, it has the same less the kickdown cable.
Old Mar 12, 2004 | 11:40 PM
z91bowtie's Avatar
no i mean the one for P R D 2 1 tha trans it's self
Old Mar 13, 2004 | 01:15 AM
aklim's Avatar
You mean P R N OD D 2 1. You missed out the OD and the N. That is the shifter cable. You can get it from the GM parts store and get the shifter from a JY.
Old Mar 14, 2004 | 01:24 AM
z91bowtie's Avatar
Thanks for your help. aklim
Fastbird93
Apr 9, 2016 07:01 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Sarahrope64
Nov 27, 2014 11:17 AM
Jul 4, 2005 05:00 PM
