tranny won't shift, WTF???
From: China now, Originally from Iowa, then worked in California
I know you fixed it, but another possible cause for that problem is a broken governor (has plastic gears that shear off, and will not allow shifts). Also, on a 700R4, it's a TV cable (throttle valve = TV) that modulates the line pressure in the transmission (no real 'kickdown' cable on it).
carguyshu
Jan 22, 2017 11:19 AM
