Tranny leak. Too much pressure?
Old Mar 19, 2004 | 08:23 PM
86 redbird's Avatar
I just had a rebuilt 350 turbo put into my car, it seems to shift fine, but it is building up pressure and pushing the fluid out the dipstick tube. What could be causing this?
Old Mar 19, 2004 | 09:13 PM
Rice Killer87's Avatar
at the bottom or the top of the tube? if its at the bottom,it could be b/c of a bad o-ring seal down there.
Old Mar 20, 2004 | 12:23 AM
trackbird's Avatar
Re: Tranny leak. Too much pressure?
It may be over filled. It may have a high stall converter that is putting alot of heat in the fluid, causing it to expand and run over. It may have a bad/plugged cooler that is causing the same problem. Or, it may have a plugged vent on the trans case (it is usually on top of the case to vent pressure).
My thoughts.
Magenta_Hearts
Mar 29, 2017 08:54 PM
dylan1303
Aug 12, 2015 02:00 AM
BigWil
Mar 29, 2015 12:24 PM
