tranny compatible?
Old Jul 20, 2002 | 10:08 PM
81formula'bird's Avatar
Question tranny compatible?
my buddy just bought a '84 z with the 700-r4 but it only gets 1+2 gear he wants to just put a new one and and he is wondering if a turbo 350/400 will bolt right up or what will be needed becuase these are much easier to come by than 700-r4's
Old Jul 20, 2002 | 11:39 PM
Stephen 87 IROC's Avatar
Post
Yes and No. If the Turbo tranny has the same bellhousing bolt pattern it will bolt right up. There's also a BOP bellhousing but won't bolt to a Chev.
You'll need a long tailshaft TH350 to be able to reuse the 700R4's driveshaft. A short tailshaft TH350 needs the longer driveshaft out of a 82-83 that came with the TH200 tranny. The TH350 is a simple swap but you'll need to buy a TH350 tranny swap kit.
The TH400 will also fit but also needs more changes. The TH400 swap kit also includes a new crossmember but you'll have to find a TH400 slip yoke since it's larger than all the other GM trannys. A new driveshaft may be required.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
