tranamission lines
Old Apr 26, 2003 | 11:36 PM
pigsticker's Avatar
tranamission lines
I've got a 92 z28 and I'm fixin to install a transmission cooler. Can anybody tell me which line is the return line, the TOP or BOTTOM?
Old Apr 27, 2003 | 11:14 AM
aklim's Avatar
I couldn't find it in Chilton's so I am not sure. However, should it matter? Both lines come into the radiator so you will disconnect both and insert both into the cooler, right?
Old Apr 27, 2003 | 06:44 PM
TheGreatJ's Avatar
If he wants to run an external cooler in addition to the internal cooler, no.
I can't tell you which is which, but I can tell you that the pressure drop across a tranny cooler is negligible, so you don't have to worry about the feed line having too much pressure for the rubber hoses (unlike a power steering cooler.) Putting it on the return side will cool the fluid slightly better though...if you're ambitious you can unhook the lines and have someone turn the engine over a couple times. The one that squirts is the feed line.
Old Apr 28, 2003 | 08:09 AM
irocz8957's Avatar
im pretty sure it the bottom!
Boss002
Jan 20, 2016 12:17 PM
pimpen1024
Aug 19, 2015 08:36 PM
Fastbird93
Jul 11, 2015 04:37 PM
Jul 10, 2015 02:23 PM
Boss002
Jul 9, 2015 03:33 PM
