tpi idle adjustment suggestions
Old Apr 30, 2007 | 11:51 PM
kandied91z's Avatar
i've got a 305tpi motor. when it starts up it idles at 1500 and once warm hits 1100-1200. this is a bit too high obviously and causes the trans to punch when shifting into gear which i don't want. what would you check to drop it back down? i've check a few of the standard things but i'm worried that maybe someone had a tune done on the car so before i go any further i'd like to see what others think.
Old May 1, 2007 | 11:55 AM
Z28SORR's Avatar
Can think of much, throttle linkage adjusted and not sticking, vacuum leaks, TB throttle hard stop not adjusted to far, throttle/plates not sticking. Do you have a TPS?
Old May 1, 2007 | 01:46 PM
Rice Killer87's Avatar
Or blown TB gasket.
Old May 1, 2007 | 05:10 PM
kandied91z's Avatar
yes i have a tps. tb gasket is new. vacuum is good pressure. cable isn't sticking, i did adjust it a bit to get it where it's at. it was higher.
Old May 1, 2007 | 05:33 PM
nikkev's Avatar
Try this:
http://www.thirdgen.org/tpimod2
Your TPS may not be adjustable since you have a '91, but the IAC portion should work. Good luck!
thenewkid
Apr 12, 2015 07:42 PM
grgguy
17
Feb 23, 2015 07:57 PM
edman
Jan 25, 2015 02:41 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
F(ast)-body
Feb 26, 2003 09:05 AM
