tpi hogh idle problem
Old Apr 4, 2007 | 10:08 AM
deathlessone's Avatar
i was driving home yesterday and my 87 with a 5.7l started idling at 2k. i parked it and found a vaccum leak and fixed it thinking it was the problem. it only lowered the idle down to 1500 rpm. check engine light is not on so i am assuming there is no trouble codes. so i am out of ideas and any help is appreciated.
thank you
Old Apr 4, 2007 | 04:22 PM
89_Irocz's Avatar
has anything gotten wet. Mine did that for about a week after I washed my engine.
Old Apr 6, 2007 | 10:46 AM
Rice Killer87's Avatar
Replace the vacuum lines.
Could be the TPS (throttle position sensor). Top connector,pass. side of T/B.
Could be a dirty IAC valve (Idle Air Control). Big circle looking thing below the TPS on the pass. side of the T/B.
Magenta_Hearts
Mar 5, 2015 07:01 AM
STR FTR 1
Feb 10, 2015 10:36 PM
edman
Jan 25, 2015 02:41 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
4586
Dec 6, 2014 05:20 PM
