tpi chip
Old May 11, 2003 | 07:41 PM
nxirocz's Avatar
Exclamation tpi chip
Would anyone like to sell me a chip for a 91-92 tpi camaro? Thanks, Will
Old May 11, 2003 | 09:02 PM
1fastformula's Avatar
Thumbs up
I have got one for a 1989 Firebird Formula 350. Email me and let me know
Later
Just had a thought....I have the Hypertech chip for the 350 TPI, but i will check on the stock chip. Will let you know
Later
Old May 11, 2003 | 11:17 PM
aklim's Avatar
89 is a Mass Air Car. 91 - 92 is Speed Density. I'll bet it won't come close to working even acceptable. What are you trying to achieve? You cannot buy a chip off the shelf and hope it gives you max gains. Not even close.
Old May 12, 2003 | 10:36 AM
nxirocz's Avatar
It doesnt mater what kind of chip, i just need a chip. Thanks
Old May 12, 2003 | 09:04 PM
Zepher's Avatar
I can sell you just the chip, or do you require the entire memcal?
Old May 12, 2003 | 09:12 PM
nxirocz's Avatar
I need what ever plugs into the ecm, that spot is blank.
Old May 12, 2003 | 09:17 PM
Zepher's Avatar
So you need the memcal.
Btw, what car is this in? Is it for the 91-92 Camaro or is it a motor swap into something else.
Reason I ask is if you put a stock memcal in the computer and the motor or TPI was transplanted into another vehicle, the motor won't run due to the VATS system, which would need to be installed into the car or disabled in the chip.
I've got the tools to re-program the chip and everything else to get it to work, but you will still need to find a 90-92 Memcal since that unit has the knock module and some other little things built into it.
Old May 13, 2003 | 11:22 AM
nxirocz's Avatar
Any memcal would be fine. Can you sell me one?
Old May 13, 2003 | 11:25 AM
Zepher's Avatar
That's one part I don't have.
I bought one from the dealer 2 years ago when I did my TPI swap.
I paid $48 and some change for mine. I sold the TPI and all related parts when the 305 died, but I still have eeproms and my programmer.
Old May 13, 2003 | 11:36 AM
nxirocz's Avatar
How much would a programer be?
Old May 13, 2003 | 11:56 AM
Zepher's Avatar
Programmer is $160 and the tuning software is $89.
Blank chips are $5.
Plug in adaptor to use the eeproms is $43. Without the adaptor, you will have to unsolder the stock eprom from the memcal and install a socket to plug in the eeprom.
Old May 13, 2003 | 04:38 PM
aklim's Avatar
$250 and you haven't even got started. You can't tune it as well as the professionals like LPE can. There would be a learning curve and it would take you some time and you risk your engine in the meantime. After you master this art, you won't use it as often as you think. That is why I opted to have someone else do it. In the last 13 years, I only have had it tuned 3 times. Once at LPE after intakes and headers, once when I went to a 383 and another time when I had to R&R the engine and I changed injectors.
Old May 13, 2003 | 10:03 PM
Zepher's Avatar
My programmer paid for itself many times over already.
I don't do any major tuning for people, just the basics like VATS, EGR, Injector sizes.
G-BODYT56
Jan 14, 2022 11:14 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
92_RS_305
Sep 8, 2015 07:47 PM
whitehooptie
Jul 22, 2015 10:25 PM
