tpi -2- carb.
Old Jun 12, 2004 | 06:21 PM
  #16
Dave89IROC's Avatar
Originally posted by Pneumatic_Tire
If it's street, then you should not even be running a 305 or 350 past 5 grand on a regular basis, unless you are asking to throw a rod.
I don't see you saying rick in there, sounds like you are saying its a sure thing
My bone stock 305 TBI sees 6000 RPM (no power there, but it goes there)regular, no problems yet
Old Jun 12, 2004 | 08:41 PM
  #17
MY91Y84's Avatar
Just an FYI there buddies...the L98 has a redline of 5,500 as does the G92 LB9...i know becasue i have one, and have driven both
the peanut cammed LB9's LG4's and LO3's had the 5,000 redline...
someone with more experiance has just chimed in
Old Jun 12, 2004 | 10:24 PM
  #18
97WS6SCharged's Avatar
The roller cammed 350/305 motors I wouldn't hesitate to take over 5k RPM. The older flat tappet cammed motors I would probably hesitate a bit if it were my only transportation. Barring that, rev it till it blows then rebuild it.
Old Jun 12, 2004 | 11:55 PM
  #19
ninetythreez's Avatar
While you have these thoughts in your head, let me ask. How difficult is dropping a carbureted pre1985 GM 350 into a '89 TPI car. A friend of mine is thinking of doing this since he threw a rod out of the opil pan in his L98 TPI 1989 T/A GTA. I have never done this swap either but want to help him wrenching. I am mostly a LT1 and 60's era hobbyist lately.
By the way,4 bolt mains mean nothing to guys like us with street and weekend drag strip duty. Trust me. I have been into the GM racing scene for about 15 years and never seen a small block motor fail through the mains. The rods give before a main will 99% of the time. It is not HP/Trq that kills em. It's usually RPMs (lack of proper oiling/bearings).
Old Apr 14, 2017 | 09:29 PM
  #20
Matthew Rainey's Avatar
Re: tpi -2- carb.
Im doing a 87 camaro tpi to carb swap is there a throttle cable bracket to buy that will fit without changing cables?
G-BODYT56
Jan 14, 2022 11:14 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
dfarr67
Apr 10, 2015 07:44 PM
