Torque converter lockup
Old Sep 17, 2002 | 04:20 PM
Erics89Iroc's Avatar
Whats up new to the board my first post.I want to find out if my torque converter is locking up. Going about 70 on the highway my motor turns up to 3000 RPMs in overdrive.Just wondering if that is normal for my car with a 700r4 and the stock 2.73 gear, since my friends 454 SS runs about 3250 RPMs at the same speed with the stock 400 and a deeper gear.
Old Sep 17, 2002 | 04:31 PM
SilentBob's Avatar
Lockup? It doesn't even sound like you are in OD. With my 2.77s I was around 2k in OD locked up @ 70mph.
SB
Old Sep 17, 2002 | 11:58 PM
im positive im in overdrive in 3rd gear at that speed the car runs around 3500 RPMs
Old Sep 18, 2002 | 01:07 AM
Gord's Green Z28's Avatar
Something isn't right with that setup. I had 3.42 gears and it would pull somewhere around 2400 RPM on the highway at that speed.
Old Sep 18, 2002 | 06:22 AM
IrocSS85's Avatar
w/my 3:73's, Im going 80mph @ 3Krpm. w/o the lockup hooked up yet. somethings wrong. slipping trans maybe? def. make sure your fluid is full and in good shape. it needs to be bright red and not smell burnt. good luck.
Old Sep 18, 2002 | 03:22 PM
The transmission has been like that ever since i have had the car, about a year. After i bought the car i changed all the fluids in the car and it still rode the same. I checked the oil and it is still fine and at normal levels.
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
