Timing and distriution
Old May 5, 2004 | 02:19 PM
84RS's Avatar
I was curious how much some doule platinum spark plugs, and a high performance distributor will do for my car. Will it hurt or improve horsepower, torque, gas mileage. Any help appreciated. And any other suggestions welcome. Thank you very much.
Old May 5, 2004 | 02:51 PM
Botch's Avatar
Probably won't help at all unless your car needs a tuneup anyway.
Botch
Old May 5, 2004 | 03:18 PM
trackbird's Avatar
Regular platnums are fine. The +2 and +4 types are a marketing tool to sell expensive plugs to the world. There is no "magic" plug. I tried splitfires when they came out (I was younger then and "low" on the learning curve). The only thing I learned is not to spend $60 on spark plugs. I went back to Bosch platnums and still run them today. Unfortunately, there is just not 30hp to be found in a set of plugs.
Have fun!
Old May 5, 2004 | 04:33 PM
aklim's Avatar
Buy regular plugs that are a good brand like AC and change them once a year and you should have no problems from them.
Old May 5, 2004 | 09:12 PM
TheGreatJ's Avatar
I recommend the single-strap Bosch platinums. I've been running them in my '91 for 6 years and only removed the first set about 14 months ago. And that was more for good measure than necessity (I was upgrading the dist., coil, and wires at the time.) The original set with about 55k miles on them were still in good shape. Just don't run them with nitrous.
I wouldn't change the distributor unless you're having problems with it or just came across one DIRT cheap and want to replace yours on principle.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
