timing cause stalling??
Old Apr 20, 2003 | 07:16 PM
slayer6x6's Avatar
i advanced my timing to 10* 2 days ago and yesterday my car stalls out of nowhere. it usually happens if im cruisng around at low throttle. recently i replaced the fuel filter, plugs, and wires. could timing be a problem with an engine with 81K miles? any suggestion helpful, thanks!
Old Apr 21, 2003 | 12:08 AM
aklim's Avatar
1. Did you do it with the advance wire off?
2. Why 10 deg? I am very sure the timing specs are 6 deg.
Set it back to 6 deg and see if it does it.
Old Apr 21, 2003 | 12:47 PM
slayer6x6's Avatar
yes the wire was unplugged when i checked it, and yes you are correct the spec is 6* but i bumped it up to 10* for improved performance. after the advance the car runs great on the highway but it doesnt have any power until 200-2500 rpm. im going to back it down to 6* and see what happens.
Noenav
Mar 1, 2019 07:38 AM
marine1bird
10
Jan 25, 2015 12:02 AM
Cam's maro
Dec 28, 2014 09:30 AM
