Ticking Noise...Please Help.
Old Apr 20, 2003 | 04:51 PM
thezisking's Avatar
I get a ticking noise for my 86 Camaro. It only ticks during acceleration in drive. It doesn't do it in park...So it's not the lifters. Anyone else have this problem or know what it is? Thanks!
Old Apr 20, 2003 | 05:22 PM
IllusionalTA's Avatar
do you hear this outside the car? in a clear parking lot? only while moving? or sitting still in drive? exhaust leaks do this type of stuff..
Old Apr 21, 2003 | 12:06 AM
aklim's Avatar
Could it be an exhaust leak?
Old Apr 22, 2003 | 05:19 AM
thezisking's Avatar
It's notan exhaust leak...Just got new exhaust....It on;y does it in gear...not in park...It can't be heard outside the car. Hope this helps...Thanks!
Old Apr 22, 2003 | 06:15 AM
LandryP's Avatar
Just because its new exhaust doesn't means its not leaking! start check the u joints, brakes, wheel bearings, motor mounts and trans mounts ect anything that moves when the car moves. One time i had a small bolt jammed in one of my tires deep enough to stay in but not enough to cause a flat, it drove me nuts trying to find the clicking it made when it hit the pavement.
Old Apr 22, 2003 | 06:18 AM
LandryP's Avatar
Also my friends monte carlo's speedo used to make this wierd ticking noise from a rusted cable.
Old Apr 22, 2003 | 07:36 AM
irocz8957's Avatar
it's probably an exhaust leak my freind just had that happen to him he took it to midas and they fixed for like 30 bucks, does your car run bad when you get on it?
Old Apr 24, 2003 | 07:51 PM
extreme79z's Avatar
Well, I am going to suggest lifters for the simple fact of no one has yet. My lifters ticked when I'd put it in gear, but not while I was in park... I didn't have to be moving tho, only as long as the car was in gear. (Lower rpms, could hear better.)
Old Apr 24, 2003 | 09:03 PM
Rage's Avatar
Before you go spend alot of money, go buy some Injector cleaner. When your injectors get dirty they can make a little tick-like noise. Just try it, what've you got to lose?
If it's a TPI that is......I dont know jack about TBI
Old Apr 24, 2003 | 11:38 PM
Error404's Avatar
I don't think this would happen only if it were in gear, but an exhaust leak DOES sound like a valve train tick, only when you open the hood can usualy tell though.
I changed my header gaskets (ahh! that was a long day!) and my engine is very quiet now!
Oh, and you say your exhaust is new? did you get headers? If so, I'd check to see if all the bolts are tight. For aluminum header gaskets, when you tighten one bolt, you have to go retighen the bolt on the other side of the tube, then go back to the first on again. Keep doing this till they both are tight.
Any way, I dont' think this is you problem because yours only happens in gear, but it's something to check out if all else failes.
Good luck bro!
Old Apr 24, 2003 | 11:57 PM
stk350's Avatar
My engine made this rattling/ticking noise at high rpms at wot. {you know, while blasting down the track } Anyways. I could never figure it out. I pulled a few degrees of timing out of the engine and vwala, no more noise.
Old Apr 25, 2003 | 08:06 AM
irocz8957's Avatar
did you find out what it was yet?
Old Apr 27, 2003 | 09:41 PM
slayer6x6's Avatar
i had the same problem, it drove me insane trying to find it, i felt like an *** when i realized what it was
Old Apr 27, 2003 | 09:55 PM
doug791's Avatar
FOR ANYONE WITH THIS PROBLEM. If the noise is coming from the engine the problem is almost certainly the head gasket. I just fixed the exact same problem and all it took was a 30 dollar head gasket and the problem dissapeared. Hope this is helpful.
Old Apr 28, 2003 | 01:15 AM
aklim's Avatar
What, in the head gasket, would cause the ticking noise anyway?
I would try using a long screwdriver or a stethoscope to listen to the engine for ticking.
